the AS186 compressor: HTF do i set the working pressure?
2K views 2 replies 3 participants last post by  rob12763
#1 ·
not sure if this is the right place to post this but here goes. (if not, please move to the appropriate forum)
just got delivery of an AS186 air compressor and airbrush and i can't seem to get the regulator to set the working pressure to correct setting. it's got an auto shut-off for filling the air tank but i can't seem to get it to fill up and shut off at 20psi.
can anyone help?
as an added incentive, there's some Rep in it for you if you can.
ta muchly
#2 ·
I didnt think air compressors shut off based on psi i thought they shut off when they reach capcity, the psi should be the rate which air comes out of the tank not the rate it goes in, and as you use the air the tank will try to fill its self again and start running im afraid.
