2000 pts of pure tanks! - Wargaming Forum and Wargamer Forums
post #1 of 15 (permalink) Old 11-23-15, 12:59 PM Thread Starter
Xabre's Avatar
Xabre's Flag is: USA
Default 2000 pts of pure tanks!
Just had to toy with this, after seeing the leaks of the new Mont'ka formations:
Steel Host formation (tanks w/in 12" of the TC gain PE)
Hydra - Enclosed Crew Compartment
LR Exterminator - Heavy Bolters x2, Hull Heavy Bolter
Command Executioner - Plasma Cannons x2, Hull Heavy Bolter
+ Executioner - Plasma Cannon x2, Hull Heavy Bolter
Emperor's Fist Armored Company Formation (tanks w/in 12" of the TC are BS4, and some fun shenanigans with Tank Shock, and using Enginseers to force worse AP rolls)
Engineer
Engineer
Engineer
Command Punisher - KC Pask, Heavy Bolters x2, Hull Heavy Bolter
+ Punisher - Heavy Bolters x2, Hull Heavy Bolter
LR Battle Tank - Plasma Cannons x2, Lascannon
LR Vanquisher - Plasma Cannons x2, Lascannon
2000/2000
Xabre is offline
post #2 of 15 (permalink) Old 11-23-15, 07:08 PM
Entropy Fetishist
Mossy Toes's Avatar
Mossy Toes's Flag is: USA
Not sure if the "Tank Commander" slot in the Armored Company needs a squadron around him (the phrasing of that in the codex is so hazily weird that I don't even know).
Also: pure tanks? Lies! Just because your engiseers are more machine than man doesn't make them not-Infantry!
Mossy Toes is offline
post #3 of 15 (permalink) Old 11-23-15, 07:41 PM
ntaw's Avatar
ntaw's Flag is: Canada
The Battle Group Command Formation stipulates that you can take Pask in place of the Tank Commander, the Emperor's Fist Formation does not. Makes me think you can't take him where you have him.
Also, plasma on Battle Tanks?
40k Related Projects
ntaw is offline
post #4 of 15 (permalink) Old 11-23-15, 07:42 PM Thread Starter
Xabre's Avatar
Bah. I'll have the Enginseers hide under the chassis or something.
As far as I'm concerned with Tank Commanders, it doesn't matter if it says unit or otherwise. It's the Tank Commander entry itself that demands a second (or third) tank to be in squadron with it.
it's not like the Steel Host, where it says '1 Hydra' instead of '1 unit of Hydras'. That's the formation being picky.
Edit: @ntaw snuck a response in there!
Knight Commander Pask is an upgrade from the Tank Commander. In my mind, that says it doesn't have to 'allow' it. It's not like some formations where you pick a Librarian vs Tiggy, etc.
Also, PCs seemed like the meanest possible guns to strap onto the Battle Tank's howitzers. Honestly, they don't relaly need sponsons, nothing quite matches up. But since THAT formation had BS4, it seemed like a better option to drop more blast templates.
Xabre is offline
post #5 of 15 (permalink) Old 11-23-15, 07:54 PM
ntaw's Avatar
If that's the way it works for Formations then why have the stipulation in one spot and not on the other? Lots of Formations have these and plenty people feel that stipulations are necessary for Unique Characters, which is what Pask is regardless of how he's taken.
Those plasma sponsons will only be firing when the Battle Cannon doesn't thanks to Ordnance causing Snap Shots. It would be a mean combo for sure, but it seems like a lot of points for something that will be very situational.
ntaw is offline
post #6 of 15 (permalink) Old 11-23-15, 08:23 PM Thread Starter
Xabre's Avatar
Hmm. Forgot about the ordinance rules, because honestly, I never use em. I'll probably either drop them, or slap on heavy bolters instead to hope for random 6s.
The way I see it, MOST special characters are their own entry. For instance, a Librarian is not upgraded to Tigurius. He's bought separately, with his own datasheet and his own entry. KC Pask, however, is a point increase on the basic Tank Commander, just like upgrading a Sergeant to a Veteran Sergeant.
For instance. The Bladewing Assault Brotherhood says that you must take a Captain or Chaplain, with a footnote that you could take Shrike instead. But Shrike isn't something that the Captain upgrades to normally, he's a special character, and certainly not a Chaplain upgrade.
Xabre is offline
post #7 of 15 (permalink) Old 11-23-15, 08:49 PM
ntaw's Avatar
I get that Pask is an upgrade, what you haven't explained is why there's a caveat for his allowance in one Formation but not another. If there was no caveat anywhere I would flat out agree with you, but no rationalization of Pask's status as a Unique Character available through upgrade gets around that.
ntaw is offline
post #8 of 15 (permalink) Old 11-23-15, 08:56 PM Thread Starter
Xabre's Avatar
Which formation makes mention of it? Neither the Steel Host nor the new Emperor's Fist one has that notation.
Xabre is offline
post #9 of 15 (permalink) Old 11-24-15, 01:19 AM
ntaw's Avatar
Formation top right, then the one we're discussing is two below it. That is the only thing that doesn't fit your explanation.
EDIT: looking back at the Steel Host, it doesn't have that stipulation either. This is a reoccurring thing across all Formations released for every army that I'm aware of, some list Unique options others don't. I always thought that if it wasn't listed it isn't allowed, otherwise why write any stipulations anywhere?
ntaw is offline
post #10 of 15 (permalink) Old 11-24-15, 01:50 AM Thread Starter
Xabre's Avatar
Fair enough. I was never looking at the full battle group, because I couldn't care less about it. I'm actually sort of surprised, because Pask still is different then all other datasheets. Oh well.
Xabre is offline
