500 point Imperial Guard army - Wargaming Forum and Wargamer Forums
post #1 of 10 (permalink) Old 11-03-15, 04:03 PM Thread Starter
comistan's Avatar
comistan's Flag is: United Kingdom
Default 500 point Imperial Guard army
Greetings,
Im just coming back to 40k after a couple of years absence and have decided to build up a Guard Army. The 4th Praetorian Rifles in fact - the building of this army is being documented in a different thread in the appropriate section of the forum.
However It would be good to get some feedback on my list and some assistance with where to go next. My plan is to build this army in 500 point segments. As such the below encompasses all of the miniatures I have thus far - which i know doesn't give me much options to customise depending on opponent.
So the first 500 points, which will form the core of my army goes like this
Company command Squad with Carapace Armour
Infantry Platoon # 1
2 x 10 man infantry squads each with a Grenade Launcher.
Attached Heavy Weapon Squad; Auto Cannons
Infantry Platoon # 2
Attached Heavy Weapon Squad; Heavy Bolters.
This comes in at 499pts.
Thoughts?
comistan is offline
post #2 of 10 (permalink) Old 11-03-15, 07:55 PM
Senior Moderator
darkreever's Avatar
I always like doing something along this line, building up in 250, 350, or 500 point segments. Makes you have to think that much harder about your selections and unit roles.
I'm going to stop here and tell you that this list is not legal in its current format. Your infantry squads need to have, at a minimum, two infantry squads and one platoon command squad. So while your two infantry platoons both have the required number of infantry squads, neither one has a platoon command squad.
Of course thats if you did not include them, a quick glance at the points used in this list does not show you using 499. It should actually come out to 440.
Given that these are the models you have, here what I would suggest:
Company command squad
Autocannon
70
Infantry platoon
Platoon command squad
Infantry squad
Grenade launcher, autocannon
65
Infantry squad
65
Heavy weapon squad
3x Heavy bolter
75
Veteran squad
Grenadiers, 2x grenade launcher
85
Total: 360/500
This leaves you with 6 lasgun guardsmen and a lot of points left to work with. Which I would honestly use to get two meltaguns, a heavy flamer, and a chimera for the veterans (+75 points), give the the company and platoon command squad one each of those two grenade launchers, and an autocannon and chimera for the platoon command squad (+65 points). You could also give that second chimera to the company command squad if you want to.
That gets you to 500 points even, adds two vehicles while only removing six infantry to your current force, and gives you tougher threats all around.
Damnation is paved on good intentions; subtle and sugar coated or blunt and honest
A hero is someone who steps up when everyone else backs down.
Popularity is what people strive for when they lack the strength to be themselves.
Seriously, is it really that hard to write reviews without spoilers?
Reporting Posts - read this
darkreever is offline
post #3 of 10 (permalink) Old 11-03-15, 08:11 PM Thread Starter
comistan's Avatar
Thanks for reply. It's my bad but each platoon has a command squad included in the 499.
I like the look of your list though, better than mine, so shall look at that in more depth when (and if) I ever get home from work!
comistan is offline
post #4 of 10 (permalink) Old 11-03-15, 08:47 PM
Senior Moderator
darkreever's Avatar
Haha, I hear you about that; feels like work just drags some days.
Even with the platoon command squads you shouldn't be at 499, but rather an even 500.
Do you have any thoughts for what you want at 1k?
post #5 of 10 (permalink) Old 11-03-15, 09:46 PM Thread Starter
comistan's Avatar
I've used Battlescribe so I guess that could be out but each platoon is 215 plus 69 for the command squad giving 499.
For my next 500 pts I guess it's time to add armour. I haven't given in too much though but I don't think I could go wrong with Leman Russ tanks. Also I like the look of the Manticore. However I don't really know how that will play out on the gaming table.
You can get a better feel for the theme of my army in the projects section titled 4th Praetorian Rifles. My plan is to be infantry heavy with armoured support
comistan is offline
post #6 of 10 (permalink) Old 11-03-15, 10:13 PM
Senior Moderator
darkreever's Avatar
I use battlescribe quite often myself, generally have no issues with it.
Now knowing that both infantry platoons have command squads, that number makes sense.
This one, however, does not. The company commander needs to get his carapace armour from the armoury, and that costs him roughly a guardsmen in points. Carapace for the rest of the veterans should run you almost double that cost. Those whole unit should be running you 73 points in its current format.
You can't go wrong with armoured support, even more so with russ's. All things considered I would definitely recommend you look into the normal russ as an overall workhorse, exterminators and punishers for infantry support, and the demolisher as a heavy hitter.
I've heard the manticore is terrible for its points, and your much better off getting a trio of wyverns for the same points.
Overall, for your next 500 pointd I would recommend considering something like:
Infantry squad
Grenade launcher and autocannon
65
Leman russ
Heavy bolter sponsons
170
Hydra battery
2x Hydra
150
Hellhound
125
510 (remove autocannon from platoon command squad)
post #7 of 10 (permalink) Old 11-03-15, 10:52 PM Thread Starter
comistan's Avatar
You're right of course. Having re-chevked the command squad have carapace except the commander.
To be honest I wasn't fussed for it but had a small number of points spare. I couldn't get in a box so just threw in the carapace
It's all academic now though as I like your 500 point suggestion more and will probably look to build that as my core base
comistan is offline
post #8 of 10 (permalink) Old 11-03-15, 11:08 PM Thread Starter
comistan's Avatar
I've just inputted your suggested 500 point list and I make it 390.
comistan is offline
post #9 of 10 (permalink) Old 11-03-15, 11:09 PM Thread Starter
comistan's Avatar
Which is the cost of the platoon command squad!
comistan is offline
post #10 of 10 (permalink) Old 11-03-15, 11:11 PM Thread Starter
comistan's Avatar
The other thing that occurs to me is that isn't my mobility hampered by having the HW in with each squad rather than as a separate entity?
comistan is offline
