Crossbows better than Handguns? - Page 2 - Wargaming Forum and Wargamer Forums
post #11 of 14 (permalink) Old 05-03-12, 12:14 AM
karlhunt's Avatar
karlhunt's Flag is: USA
Let's be honest, it's not to discourage using 20 mm bases so much as it is that with the new infantryhammer rules coupled with the new awesome that is the detachment rule they had to increase points cost to get people to bother with the travesty that is cavalry.
Then again, the look on your opponent's face when you drop a block of 40 knights totally makes up for the fact that the unit is completly unmanageable.
C'mon, Click my Daemon. You know you want to.
karlhunt is offline
post #12 of 14 (permalink) Old 05-03-12, 03:15 PM Thread Starter
Words_of_Truth's Avatar
Originally Posted by jigplums View Post
i think crossbows are better, favouring the range over armour piercing. 10 shots that get to shot because of range is better than 10 armour piercing shots that are out of range.
btw what nerf to shooting are you referring to?
Firing in 2 ranks and volley fire were both buffs?
I read that there was greater negative modifiers to shooting as well as the fact most units are huge now, so shooting doesn't make as much impact.
Words_of_Truth is offline
post #13 of 14 (permalink) Old 05-03-12, 04:35 PM
WFB Moderator
Tim/Steve's Avatar
No, there are no new shooting mods but having fewer, larger units means that magic items that hamper shooting are a little more common.
With bigger units shooting finds it harder to massacre enemy units, but massed shooting can very rapidly smash even big infantry blocks... let alone its standard role of weakening enemy units so that your own infantry can kill it (or drop the enemy below steadfast levels).
Tim/Steve is offline
post #14 of 14 (permalink) Old 05-03-12, 05:38 PM
olderplayer's Flag is: USA
It is more of an issue as to how many shots you get, what BS, and what strength and AP or not, whether cover is on the table (forests, obstacles, screening units), and what the targets are. In 7th edition where there were a lot more small units where shooting could kill 25% and induce panic tests or cut down a unit or finish off the last remaining models, shooting had more value. But against certain armies in 8th edition, shooting can be very effective. Orcs and Goblins often play units of snotling pump wagons, mangler squigs, and chariots that can hit hard and cut through elite units. Unit of crossbows or handguns against such an army are entirely worthwhile. Also, one should not underestimate the value of shooting in slowly eroding the size of a horde unit to the point that one can finally deal with it once in combat.
Units that can move and shoot (march and shoot in the case of Empire archers and other skirmishers and fast cav), can be very effective.
When I play dark elves, I almost always have two units of repeater crossbowmen. They have better BS and two shots apiece from the first and second ranks and, with 24" range, usually get at least two turns of shooting and kill enough to earn more than half their points costs (which is wht one needs) and still can hold something up or act as diverters or even charge some skirmishers.
When I play Daemons, a unit of six flamers is always one of the best units on the table for the points cost. The ability to march and shoot with S4, flaming attacks, good BS, and D6 shots per flamer is huge. Plus they are skirmishers with decent toughness, a ward save and unbreakable.
Leadbelchers are another example of a great shooting unit.
The problem with handgunners and crossbowmen of empire and dwaf armies is that they are move or shoot troops with only average BS. That means that they have to be positioned correctly to anticipate the opponent's units that can be targetted and opponents can avoid being shot by deploying out of range, screening units, and moving out of forward arc for some or all in the units. Since you cannot move and shoot, you have no option of moving forward to get in range to shoot on turn one (especially with handgunners) in many battle scenarioes and cannot turn the unit (using swift stride) to shoot something threatening a flank (like skirmishing scouts and ambushers). That is one of the reasons why I was surprised they increased the point cost of hangunners and crossbowmen, yet they reduced the points costs of archers (which are skirmishers and can, therefore, march and shoot, are harder to hit, have unlimited free reforms, and can wheel as needed). For those reasons, I am favoring running archer detachments (including to hide an engineer in them) instead of handgunners and crossbowmen and using the Hellblaster volley gun (which can pivot to shoot) with an engineer in range as the main shooting option due to the number of shots and hits and strength 5 with AP it provides.
olderplayer is offline
